Ae71 Running Like 90Year Old Dog Balls
ill give it a try tommorow morning, and ill update then, hopefully its just a lead or spark plug! fingers crossed haha
puts my mind at ease^ haha ill take the spark and lead out to see if there is any spark or if the spark plug is wet, when engine is on. if wet then head gasket
just tested cylinders and the fourth isnt firing, also a milky oil cap so I'm guessing the head is cracket/gasket :(
almost 2 to 3 months since i filled it up last? edit: yeh it might be old fuel, ill go get some tommorow and do i need to add that lead additive to it? might even be a timing issue! ill freshen it all up with new leads and spark plugs.
finally took my ae71 4ac for a drive, had to go and buy a new battery as the old one was screwed. put the new battery in fired straight up and let it warm up for 20mins, sounded fine as i got it tuned like a month ago but as i took it for a test drive it just started to run like shit, skipping beat and i just don't know whats wrong with it. would it be that it hasnt gone for a drive for like 3 months? any help is appreciated! cheers, aaron
What Is This Wire
thanks guys, ill test some speakers into it tomorrow and see if it does anything, if it doesnt do anything ill probs just leave it
What Is This Wire
- 4Afe Vs 4Age
Shocks
just typed the shock number that was on the tube and it turns out to be a suzuki, duno what model though, I'm guesing that having the shock which is at full extension when just in the air and with the spring in a not so good idea? edit: just measured the extension and compression. extended: 37cm and compressed: 22cm, this good or not so good
Shocks
they were kyb shocks and when i goto jack the car up with the shocks in it reaches the welded hoop but then the whole car starts to rise not just the diff?
Shocks
so does all them shocks in that thread fit an *e7*? thanks for showing it by the way
Shocks
yeh i was thinking of putting sominthing to strengthen the first one, probs just chuck em out what other shocks fit in the rear of a ke70? or could i use the stock ones or will the spring just fall out when driving?
Shocks
hello i bought shocks the other week and reliesed that someone has welded another circle mount on the first hoop, photo will explain, just wondering if this is safe to use the second one as that only fits the first one doesn't reach?
15X7'S Fit With Out Rolling On Ke70?
whats the difference between a FWD rim and a RWD one? yeh ill test fit one just incase
havent bought them yet but here's the add, http://www.gumtree.com.au/s-ad/adelaide-region/wheels-tyres-rims/15-roh-mag-wheels-4-stud-200-o-n-o/1004230765 he doesnt know the offset but looks pretty + you think they will look good white ae71?
84Co-Rolla
