Stamsaas
  1. Can follow the building progress here, if there is any interrest : http://www.superturb...ad.php?tid=4390 Feel free to comment here :)
  2. Wow, forgot about this... Guess this will make the Ke slip the tires :) :)
  3. Thanks guys! :) yes, 5 cylinder motor :)
  4. A quick resume; Removed dash and made room for gearbox Coilovers with new calipers aside Welded the coils and mounted ae86 cambertops The rims engine with radiator an cooler enginebay layout BMW brakedisc redrilled to 4x114,3 And todays work Many more pics are here, in the photobucket album. If there is any interrest I can try update this more often :)
  5. The engine is originaly turbo, yes. OM605.960, but i will use Holset HY35 turbo, and om605 n/a pump tuned to 180cc fuel and external ALDA :) can do a larger update when I come home from hollyday :)
  6. Thanks :) as you see on the other pic I'm in the middle of the project now a days (acculy in Thailand for hollydays right now tough), and its getting really seriously rebuildt. Havent uppdatering this tread because I didnt think there was any interrest.. :)
  7. The new engine is a OM605 from Mercedes with a 5speed manual box :) will be tight ;) Yes, the car is parked on a plastic sheat, all Cars driving on the track must have that when standing in pit. New rules this year :)
  8. Now the winter is around the corner here in Norway, and that meens that its time to park the car in the workshop. Have a short videoclip from the other day :) not so bad for a 4K :) When I park it the fun begins. New engine is ready, and gearbox, and I will during the winter get that installed with a rollcage, fuelcell etc etc. Time to start the project :) It will be a budget build, so the goal for next season is to have a working car, and fix up build problems and issues when finding them :)
  9. Long time, no see, here are some photos from sunday when i tested it on the track :) Worked out really well, but way to litle power :P The turns impressed, and it cornered like a go-cart :) Getting ready for the swap, only needs a gearbox to the engine, and I will start making room :)
  10. It has a 4k engine, and it is auto rear diff with 4speed manual. But don't Think it will take ti much beating.. Picking up new engine tomorow :) will be installed in the winter time, så its ready Next spring :) big rebuild coming up :)
  11. Thanks both :) don't think I will replace the mirrors, saving up all the money to engine swap instead. How much can the rear axle handle? is it just shit and will break at once, or can I use it to testdrive new engine? :)
  12. Thanks guys! :) About time to add more pics here now I'm using the phone with a GPS speedometer because the small wheels makes the speedo show way to much. I have got info that the car is an auto that is rebuildt to manual, but still with the auto rear diff. and with theese wheels it have a mekanikal topspeed limit at 155kmH at the speedo, witch is 125kmH on GPS :P And look what i found in the barn, from my fathers earlyer days :D Will start the engine rebuild this summer, but it will take some time as I'm using the car as an daily in periods now :)
  13. Thanks :) love the stance myself, just want it a bit more down on the rear :) just to save up to a engineswap now. Is there any easy cheap tricks to get more power before the swap itself? can't Think of any, but if there is any way..? :)
  14. It is fully driveable in this hight also :) it was 15cm drop in front and 12cm drop at the rear. Will Get the rear adapters down so it gets ET-5, than i can Get it down 1 or 2cm more :) The police isnt happy about it, but the local police usually let it go if you not are breaking the law in other ways.. But there are also not local police that can take the plates if in the right mood.. Some more better pics
