Everything posted by da_snuff
Rollmaster Cs9000 Adjustable Timing Gear
It's a 40A110 grind from Clive Cams in Vic, has 240 deg duration @ 0.050" and .296" lobe lift inlet and exhaust (with 1.5 rocker ratio should be 0.444" valve lift). I have installed it in the stock position as I am not that clued up on valve timing yet, so will get it going (still a way to go getting the bits and pieces I want) and will then do some more research and maybe play with valve timing. I actually bought the engine with most parts needed to assemble, so the previous owner did the hard work on deciding what to buy and that is how I ended up with the roll master setup.
you will also want the twin chain tensioner and chain damper if you didn't already have a twin chain. Can buy these off ebay I think.
pics! note that in the one where you can see the camshaft thrust plate I have not yet rotated the cam dowel pin to line up with the punch mark. Also helps to mark a line or dot off from the thrust plate punch mark so that you can still see where it is when you slide the sprocket on, just incase you accidently rotate it and can then correct it.
have just installed one of these on a 5k, if you don't want to go advancing or retarding it it is easy. They have a dot stamped on the cam pin hole that is equivalent to factory timing. The A & R either side of that depict which way to rotate it for advancing or retarding. This dot should be lined up with the punch mark on the cam thrust plate. Then get #1 piston at TDC and install the two sprockets with the chain on. You may need to play with the crankshaft sprocket by rotating it a tooth at a time on the chain to get the line ups correct. Once on recheck the dots are still in the right places. There is another punch mark on the crankshaft sprocket that if correct will end up being able to make a straight line from it, through the centre of the crankshaft, through the cam thrust plate punch, through the cam sprocket punch mark, and then through the centre line of the camshaft.. I may have made this sound more confusing than it is, but in practice you should see what I mean. Torque camshaft pulley bolt to 40-47 ft.lb, may need to jam a rag in between the chain and sprocket teeth to prevent turning. Good luck! and if I am wrong on anything... sorry... will put up some pics once I figure out how..
Ke10 Tie Rod Ends And Bushes
Hell yeah I bought one of those bad boys, see the "10 available, 1 sold" thats me right there Might buy another just for the sake of hoarding rolla parts :lovin:
