4Age Red Top Small Port Plus Turbo?
yeah its just for a laugh really plus i have a few spare turcels when it breaks gearboxes etc
or can any gze computer be plugged into my loom with gze injectors aswell?
ok i have a very tidy 1993 redtop smallport map sensor version and I'm putting it in a 1882 tercel 4x4 for a laugh also have a rb20 turbo and manifold for 4age bosch 044 surge tank intercooler etc what is the limitations with the ecu on these? can i put it on and run any boost on the stock ecu at all with a rising rate regulator and 98 octane fuel its all just for a bit of fun really don't want to waste heaps on a aftermarket ecu was hoping to get away with a rising rate regulator and a dodgey extra injector can you run gze injectors or any upgrade like that with the stock ecu? any info would be great thanks
4Agze Plus Turbo ?
just looking at the factory power for the later gze map sensor version and there only 120kw roughley what will one make with a turbo and the stock ecu and injectors near maxxed out because if its not much i may aswell just get a blacktop 20v
4Agze Plus Turbo ?
ok so i just need to find a 4age rwd inlet manifold then? does all the sensors and throttle body off the gze bolt up to it?
4Agze Plus Turbo ?
planning on doing a 4agze engine conversion can i just remove the supercharger and put my turbo setup on I'm using a steam pipe manifold and a rb20 turbo not after any huge power will the 4agze ecu and injectors be ok on 10 psi? is there any problems doing this?
4agzeturcel
