4agzeturcel
Everything posted by 4agzeturcel
  1. yeah its just for a laugh really plus i have a few spare turcels when it breaks gearboxes etc
  2. or can any gze computer be plugged into my loom with gze injectors aswell?
  3. ok i have a very tidy 1993 redtop smallport map sensor version and I'm putting it in a 1882 tercel 4x4 for a laugh also have a rb20 turbo and manifold for 4age bosch 044 surge tank intercooler etc what is the limitations with the ecu on these? can i put it on and run any boost on the stock ecu at all with a rising rate regulator and 98 octane fuel its all just for a bit of fun really don't want to waste heaps on a aftermarket ecu was hoping to get away with a rising rate regulator and a dodgey extra injector can you run gze injectors or any upgrade like that with the stock ecu? any info would be great thanks
  4. just looking at the factory power for the later gze map sensor version and there only 120kw roughley what will one make with a turbo and the stock ecu and injectors near maxxed out because if its not much i may aswell just get a blacktop 20v
  5. ok so i just need to find a 4age rwd inlet manifold then? does all the sensors and throttle body off the gze bolt up to it?
  6. planning on doing a 4agze engine conversion can i just remove the supercharger and put my turbo setup on I'm using a steam pipe manifold and a rb20 turbo not after any huge power will the 4agze ecu and injectors be ok on 10 psi? is there any problems doing this?
