Romulus
  1. Greetings all, I Have a 2005 Corolla which has no headlights at the moment. On First setting of light switch - parking lights and instrumentation lights work. On Second setting - no low beam. Push light switch stalk toward dashboard - no high beam. Pull light switch stalk toward steering wheel to flash high beam - high beam works. I removed the low beam bulbs and connected them individually to battery power just to make sure they weren't both blown - they work. I then located the 2 15 A fuses in the fuse box in front L/H side of engine bay (L/H & R/H Headlight) - they're both O.K. Then I took out the fuses and checked across the fuse fixtures with a multi-meter while headlight switch was turned off or turned to parking - no power there. Then turned the switch to low beam - power is there. So the light switch appears to be working correctly. Then I put the fuses back & tested the plugs that go onto the light fixtures with the meter while low beam was switched on - no power there. So..... Either there is a problem with the headlight relay, or maybe wiring has been damaged or a junction connector is faulty I would think if wiring has been damaged, a short would occur, in which case the fuses would have blown. As for a headlight relay, I can't seem to locate it. According to the illustration on the inside of the lid of the fuse box, right next to the two 15 A Headlight fuses there is a space allocated for a 50 A (EMPS) & 40 A (Head Main) fuse or relay but in my fuse box there's Just a big blank space where they should be. Any thoughts on locating it, or any other leads would be appreciated, Regards, R.
