Greetings all,
I Have a 2005 Corolla which has no headlights at the moment.
On First setting of light switch - parking lights and instrumentation lights work.
On Second setting - no low beam.
Push light switch stalk toward dashboard - no high beam.
Pull light switch stalk toward steering wheel to flash high beam - high beam works.
I removed the low beam bulbs and connected them individually to battery power just to make sure they weren't both blown - they work.
I then located the 2 15 A fuses in the fuse box in front L/H side of engine bay (L/H & R/H Headlight) - they're both O.K.
Then I took out the fuses and checked across the fuse fixtures with a multi-meter while headlight switch was turned off or turned to parking - no power there.
Then turned the switch to low beam - power is there.
So the light switch appears to be working correctly.
Then I put the fuses back & tested the plugs that go onto the light fixtures with the meter while low beam was switched on - no power there.
So.....
Either there is a problem with the headlight relay, or maybe wiring has been damaged or a junction connector is faulty
I would think if wiring has been damaged, a short would occur, in which case the fuses would have blown.
As for a headlight relay, I can't seem to locate it.
According to the illustration on the inside of the lid of the fuse box, right next to the two 15 A Headlight fuses there is a space allocated for a
50 A (EMPS) & 40 A (Head Main) fuse or relay but in my fuse box there's Just a big blank space where they should be.
Any thoughts on locating it, or any other leads would be appreciated,
Regards,
R.
