harryrolla
    34
  • Real Name
    harry
harryrolla's Achievements
  1. sweet cheers very helpful !
  2. sorry guys big head bang moment having one of them days! admin please delete thanks>
  3. Hey bit confused to as which one my charge light is trying to wire a 4age alternator in ?
  4. Got a 4age 16v Bluetop Can I just replace my coil with any coil or does it have to be a specific one ?
  5. hey all i have brought a 4age and it didnt come with a map sensor or air flow meter. so i need to know which one i need to buy. its a AE82 Corolla 4AGE - (Largeport / TVIS / MAP / Yellow Plugs) ecu numbers are toyota 89661-12080 175700-0561
  6. Here's the photos the clear hoes goes to charcoal canister
  7. hey i have discovered something ! yay when i took injector 1 lead off and placed the noid light in it ran but only on three cylinders and stalled shortly after. that was the longest the motor had ran .... I'm starting to think its a wiring issue. i have 5 brown wires all connected to earth point, three which are the injector ones ? on the back of the intake manifold and 2 others on the cylinder head. Hope this info helps :)
  8. Fuel system is done vl lift pump to surge tank to Bosch 044 to dual fuel filters there is fuel pressure at the fuel rail. Still not wanting to start. I'll check the injector pulse again tonight.
  9. Hey I have brought a surge tank and a genuine Bosch 044 overkill yes but it has minimal use and was a good price :) I'm going to get a vl lifter pump in the tank and wire the pumps up to the ecu I'll let you know how I go :) Yeah vacuum line is on the return fuel pressure regulator. Defently the right way around
  10. Put it bellow and no difference but sounds like it's pumping better down there so will probably keep it down there. I replaced my injectors 4age bigport with cleaned and flow tested one with all new rubber dark red ones. Is it possible it's a wiring issue ?
  11. Fuel pump is wired into on at the key. Looking into wiring it in to the ecu but it should run without it wired up to ecu ?
  12. No I take that back not really any difference in running
  13. Yes fuel pump is located above tank in the boot. I just put in a bigger then stock fuel line and it seems to have helped. But the car is revving up nicely then stalling.
  14. Oh and the fuel was closed air tight in the fuel tank for about 2 years I added 15 liters of 98 to it 2 days ago
  15. Set it too 10 btdc and it ran woohoo, but not for long it died It sounds like the fuel is surging ? So This is my fuel setup, I'm running a fake Bosch 044 I got off eBay it was advertised as real one but it's not ... And then just the standard ke55 fuel lines to stock 4age fuel filter
