Thank you for the response Altezzaclub. I will be checking all those things out tomorrow, I am quite positive the batteries are good and i was able to pull the positive lead off and the car kept running so I am pretty sure the alternator is still charging.
It really seems like there is a lose connection somewhere, and its getting worse every time I try to idle the car as it its vibrating more and more to the point of separation only i have looked up and down in the engine bay for a loose, melted or stripped wire. All fuses are still in good order it would appear.
So I will try the wire from positive battery terminal to the positive terminal on the coil and see if that works then we will know if it is what we think it may be. The Ignition key area thingy magijer.
