Bluebeast
    31
Everything posted by Bluebeast
  1. Alright, so i have replaced the lift bolts, they were looking pretty rough, but still all there. Ive tested the solenoids, and both are functional (at least when i put 12v through them). And the filter screens are also clean. I made a friend that used to work at Toyota who has some equipment to manually turn on the solenoids so we can test them. A further question i have is, could there be any other cause for the noise, which i can only really describe as "screeching" from 4500rmp onwards?
  2. Thanks mate, I'll have a look into it
  3. Sup Gang, Recently I bought a 2004 Sportivo, and it is in really good shape, aside from the VVTL-I, when i get high in the revs it starts sounding bad. I figured it was a bad solenoid, but I'm having a hard time finding the VVT solenoids for the 2zz, was just wondering if anyone knows if the VVT solenoids are the same on the 1zz? Thanks, Lewis
  4. Appreciate the help mate. At least i know where i should be looking now. Thank you
  5. Have to get round to checking it out when it is not so bloody hot outside. Also just asking if there is a possibility of a faulty MAP sensor or something? Cheers
  6. Sorry it took me so long reply It came on a while ago but got progressively worse. I didnt do any work on the engine or anything like that. It will start off at 1600 and when the car heats up it will drop to about 1200 briefly. But when i then drive it, it will stay at 1800. I don't have an aftermarket ECU either. Thanks Banjo
  7. Hey guys, my 7afe AE112 has a very high idle (1600-1800) and i don't know why. I have already cleaned the IAC and not seen a difference. Is there anything else i should be looking at to get my idle down? Thanks
  8. So after looking at other forums, it seems toyota did not provide a relay space. The best there is, is a 15amp fog light fuse. Looks like I'm going to be doing some wiring!
  9. Hey Banjo, yes its identical apart from the foglights function. Plugged it in and everything works apart from the foglights. Is there a relay that currently is not in my car that i need to source? Cheers
  10. Hey, thanks for the info, just wondering if it would be a slightly different process for a headlight stalk with a fog light switch. I got one of those but don't know if just swapping it will allow it to work. Any ideas? Cheers
  11. Had a look in there and there seems to be some wires! Hopefully all goes well then. Thank you!
  12. Hey guys, I'm look to add foglights to my pre facelift AE112. I'm wondering if the necessary wiring is tucked away in the car somewhere like with some electronic components or if i have to do my own wiring. If its the latter, how would I go about that? Cheers!
  13. Thanks bro. Its the whole thing, not limited to any direction
  14. Ideally all of them, but my main current concern it the one that holds the shifter ball. Thanks Hiro, I should have known you'd reply 😉
  15. Sup everyone, Does anyone have a source for gear bushings for a 98' ae112, I'm trying to get the play out of my knob? Thanks yall
  16. Thanks mate. It is literally just aesthetic because my calipers are visable through my new wheels lol. Red or yellow calipers? Is on a blue car, red adds horsepower. But yellow will drop panties
  17. I want to put better calipers on my AE112 but i don't really know where to look. Any help?? Love you all.
  18. Heyo, I know different brands of cars have different airbag wiring harness'. But do they differ between different models? (i want a 2002 levin steering wheel in my 98 conquest)
  19. After spotting a corolla sportivo near my house, i now really want to get a sportivo body kit for my pre-facelift rolla, but I'm under the impression from different forums that they cannot go on pre-facelift models. Can anyone confirm this / explain why? And is there any way i could get one on my car (without using cable ties and duct tape)?
  20. At work i see another AE112 with the round headlights. But i see it has foglights and it looks so much nicer to me. Is it a situation of just getting lights and fitting them in. Or is there going to be issues along the way?
  21. Thanks guys. Love you all ♥
  22. I'm so desperately sick of steelies on the rolla. I'm also on a bit of a budget so I'm not really looking to pay for shipping from anywhere. Anyone know of wheel shops that stocks a range of 4x100? Thanks
  23. Thank you! Edit: after a little research into the symptoms of a bad throwout bearing. It would appear that this is not the issue. The search continues!
  24. I have a squeak that i can hear while i drive. I'm fairly confident that it isnt a belt squeak because it almost sounds as if it is coming from below the car. The only clue I can give is that there is no squeak in neutral. Only when the car is moving. But the squeak goes away when i put even the slightest amount of pressure on the clutch. Any guidance would be muchly appreciated. Cheers
  25. Sorry i couldnt thank you sooner. It stayed in for about a day before it popped right back out again unfortunately 😞
