Chandika
    8
Everything posted by Chandika
  1. I need 1983 Corolla KE72 Wagon Headlamp frame set. Is there anyone??
  2. Connection done. 12v indicate between coil(-) and earth. BO wire goes to distributor from resistor up point. But no spark in the plug and plug wire at engine start. 😞
  3. Can u explain how do we can start engine with eternal battery supply to ignation coil? Ballast resistor actual valu - 1.4ohm Ignation coil 1.9-2.2ohms
  4. All are worked properly. I needed restore the wiring. All removed. My alternator has 2wires. 1x Voltage regulator This is ke72 flatroof 1983
  5. What are the voltages and what are the measuring points? Cany find the fuel cut valve, but when key on the IG position 'its here click sound at cab. Other all wiring removed.
  6. What are the voltages and what are the measuring points? Cany find the fuel cut valve, but when key on the IG position 'its here click sound at cab. Other all wiring removed.
  7. can't start engin. Starting motor working. All wirings removed and only ignation wiring. Help please
  8. do anyone have corolla KE72 1983 wiring diagram? Thanks
