chesmari
    11
Everything posted by chesmari
  1. Thank you. The manual rack itself was from a 1981 Starlet, the knuckles are from an AE86, as well as the tie rods. The steering shaft is from a 1st gen Tercel and the steering column is from a 1982 Celica. Clamp collars were welded on to angle iron to make the bracket which was welded to the crossmember. I wish I could do a complete write up about it, unfortunately I've moved so many times and lost all my notes. HTH. Ryan
  2. Thank you Rob. These cars are quite rare nowadays. The fact that here in the US, the TE37 was only offered for 2 years, 1975 and 1976. Plus it was an econobox, no performance parts for it, no G motors at all. Much easier to get a muscle car, much easier to buy parts for them to because you can do it through a catalog. It's still reasonable if you find it. Ryan
  3. Actually years and it was well worth it. Ryan
  4. Thank you. Ryan
  5. http://www.youtube.com/embed/lO-fXRamSAg Ryan
  6. Tidied up the engine bay, rebuilt my smoking turbo and finally found a plug in 3 core radiator. Will be roadworthy and registered next week. Ryan
  7. Finally got this going.... finishing up some the small details to get it registered... Ended up ditching the Mega-squirt for an SDS-EFI..... Will get it on the Dyno soon.... Ryan
  8. Thanks all. Cars here doesn't need an engineering inspection. Most states are concerned more on smog enforcement than anything else. The 1975 and older law is only on the smog side and I believe only in the state of California, pre-1969 in Nevada. One law states, in Nevada anyway, that your engine has to be as old or newer than the chassis if you are doing an engine swap. The car will be dyn-tuned as soon as we get it running. Mega-squirt is arriving in a few days. Ryan
  9. Name: Ryan Car: 1975 TE37 SR5 started Pearl White now British Racing Green Motor & Driveline: SDS EFI 3TGTEU w/ 440cc 7MGTE injectors, front facing intake manifold, T3/4 turbo and FMIC, Supra W58 w/ IS300 short shifter, Ford 8.8 with 3.73 gear and LSD, 3 inch mandrel bent exhaust with Magnaflow muffler. Suspension & Brakes: AE86 front struts, shortened to suit an MR2 SW20 5 way adjustable Tokico shocks, coilovers and adjustable T3 camber plates and NRCA. Straightened leafsprings with 8 way adjustable TRD blues. FC3S Rx7 4 pot calipers up front. Wheels & Tyres: Enkei with 195-50 rubbers Interior: Acura/Honda Integra seats, VW Rabbit center console. Re-vinyl was needed for the dash. All plastics were refreshed with vinyl paint. Body: Refreshed entire chassis with new metal and new color. Bumper bars were sent over from NZ. US bumpers are ugly. Other: Replaced entire wiring loom with a brand new universal harness. Steering is upgraded as well with a Starlet manual rack & pinion, and CelicaSupra column with tilt. Air Conditioning is online. All chrome parts are refreshed and polished. That's all for now. Ryan
  10. Thank you kindly. Ryan
  11. Not a KE, TE37 to be exact, hopefully it's ok :dance: Name: Ryan Car: 1975 TE37 SR5 started Pearl White now British Racing Green Motor & Driveline: 3TGTEU w/ 440cc 7MGTE injectors, front facing intake manifold, T3/4 turbo and FMIC, Supra W58 w/ IS300 short shifter, deciding between a Ford 8.8 or a Volvo Dana 30. Suspension & Brakes: AE86 front struts, shortened to suit an MR2 SW20 5 way adjustable Tokico shocks, coilovers and adjustable T3 camber plates and NRCA. Straightened leafsprings with 8 way adjustable TRD blues. FC3S Rx7 4 pot calipers up front and disk conversion on rear. Wheels & Tyres: Rota Rb, 15x7 fronts 205-50, 15x8 rear 225-50 Interior: Acura/Honda Integra seats, VW Rabbit center console. Re-vinyl was needed for the dash. All plastics were refreshed with vinyl paint. Body: Refreshed entire chassis with new metal and new color. Bumper bars were sent over from NZ. US bumpers are ugly. Other: Replaced entire wiring loom with a brand new universal harness. Steering is upgraded as well with a Starlet manual rack & pinion, and CelicaSupra column with tilt. All chrome parts are refreshed and polished. That's all for now. Ryan
