blonka
  1. hey, i just brought a standard te71 and it feels like driving a boat. does any one know if there are lowering springs i can buy? or any other model that has the same springs? thanks
  2. was realy just after the diagrams but if people can help would be just as good, whats hapend is my mum tidyd my garage with out asking and chucked out the part of the wiring that goes from the positive battery terminal to evrything, i know the main wire goes to the starter but I'm real confused about where all the other wires used to go. is it just the regulator and some other things????
  3. hey I'm after a couple of wiring diagrams, one for a ke35 aqnd another for a 4k, got a bit stuck with the wiring, any help would be great thanks
  4. hey, ive put a 4age into my ke35 and run in2 a issue with the wiring, my issues prety much start from the positive termenal on the batery, do i need to wire the 4age alternator into the same wires as the old 4k alterntor? and is there anything that should have wires going 2 it before the alternator? if any 1 knows were to get wiring diagrams would be a big help ir just pics of what people have done here thanks
  5. far out those photos were so helpful thanks heaps, just one question does the master cylinder go throught that hole to the left of ravens photos between the 2 bolts?
  6. just checking did you mount the master cylinder where the cable used to come out?
  7. the speedo cable idea wont work because the speedo cable is on the wrong side if the brakes to change the pivout point do i prety much have 2 make my own pedal box?
  8. hey, ive recently put a 4age with a t50 box in2 my ke35, and ive run in2 a issue with the mastercylinder/clutch pedal i don't know how to get the clutch pedal to pick up the mastercylinder. how have people done this before on there ke3#? mounting, changing pedal etc pics would be a great help, thanks
  9. hey would this pump be good for the pump 2 the surge tank? http://www.trademe.co.nz/Trade-Me-Motors/C...on-89622748.htm
  10. sweet thanks heaps guys got it sorted now
  11. hey, I'm puting a 4age bluetop into my ke35 and ive run in2 a few problems 2 do with the efi do i need a fuel filter? and if so where should it go? it previously had a 4k in it and i can't find a return fuel line, i seen a line coming from the fuel tank and then it dissapears in2 the chasis, do i even need a return fuel line? and last question where does each thing connect to on the inector rail? i have atached a picture of it to help
