4AGE_BOI
Members-
20 -
Everything posted by 4AGE_BOI
My initial thought was the fuel pump..... I'm replacing it anyway...... I have a walbro 550hp with a 2 ltr surge tank.... I'm going to install that just thought maybe there would be something else.... The fuel lines (on idle) are solid as, although i can't feel them at 7000 rpm,
100 octane sometimes more.
Hey Guys.. So i ave just finished a 4 month silvertop engine conversion.... i am having some issues. The engine has been completely re built... And it is in an AE82 Rolla CSX the twin cam 16 V came out of it. The 20V ECU is in it, as well as the 20V injectors. Now the Silvertop 20V is rated at (121 kW) at 7800 rpm mine will not rev past 7000 it seems like there is not enough fuel. Do i need to replace the 16 V Fuel Pump? Also the torque is supposed to have 162 N·m at 5200 rpm, The most of my torque seems to come in at 3900 RPM. It is really bothering me. Any thoughts at all...........
I'm up for it! My rolla is at J-racing untill the 27th, so anytime after that i'm keen as.
Hey, I have just made the same conversion in the extended back version of your car. Awesome Huh, ATM it is at J-Racing in ACT and is getting the following: Port, Polished and Balanced Head. Valves Seated, Springs, shims and Buckets. TRD Headgasket Higher compression. It already has the following: 272 Deg cams. 550 Hp Fuel pump, new fuel lines. Twin Plated Clutch. We should meet up!
Thanks heaps man,, It looks like my sparky has figured it all out. Apparently, the ignitor module was faulty, so we are just waiting for the new module.. Can't wait though, my car has been off the road now for 2 months. Can't wait to drive it though. I'll let you know how we go.. Cheers mate.
Lol, fair enough. Well any feedback from the mechanic when you get yours fixed would be awesome.
Cheers man, that would be awesome. So does yours not have the lumpy idle or the fuel cut.
Hey guys. Went to pick up my 82 rolla after the full re-build on Sat, big issue. The motor is a TRD Spec 20V Silvertop. Once started the car has a very irratic idle, i mean it bounces from 1k - 2.5k. Then when driven the car will accelerate normal untill 3500 rpm and the fuel will cut, and it sounds like it's at the end of the gear. My sparky is having a look through the ECU, and we will start troubleshooting soon. Any help or idea's will be awesome. Cheers.
Hey, Yeah for sure, i'm in the ACT, and my paint contact is good. He sprayed my road bike, and is going to spray my car, he has done a lot of work for me. Just let me know.
very nice man, highly respectable. I have just completed a rebuild myself, not to your extent, but i am building a track car. Mods incl 20v 4AGE VVT 272deg cams surge tank fuel pump clutch Brake's cold air intake Soon to come will be. Motec ECU coilovers full exhaust. Does make some power, but in a fwd AE82 Rolla, its not what i'm after, long gears and wide torque is what i'm looking for, and i have seemed to acheive it. I'll post some pics later. Cheers mate,
For sure, got business in Adelaide anyway, mrs family, may as well see them, and race you at the same time. I'll prob be there around x-mas as well.
Hey guys I am new to the forum and thought i would introduce myself. Name is Shane-0, and I am currently rebuilding an AE82. So far installing: Silvertop with VVT 272Deg cams with a larger lift 2 lt surge tank 550 hp bosch fuel pump heavy duty clutch cold air intake with the AFM sensor inputs. Its hauling some serious ass...... Next to come will be a restoration of the white paint, and a black leather interiour. Curious to meet all the talent on the forum, feel free to say g-day. Plus if anyone needs a hook up with paint, i'm your man. Got a lot of mate's in the industry. Cheers.
Lets do it, say when and where. Even with bost man, there won't be much space, if any between you and me.
sorry mate, new to the whole thing, will get it eventually though,
ACT. how about you? Work for the government,
Na man, new to the whole forum thing, my bad! Bahahaha
Hey mate, You would be wise to have a look at the NA options. I have just finished a conversion from a 16v to a silvertop 20v in my AE82. Man it hauls ass. Incl. Silvertop with VVT 272Deg cams with a larger lift 2 lt surge tank 550 hp bosch fuel pump heavy duty clutch cold air intake with the AFM sensor inputs. 4in21 exuast manifold with the same sixe pipe all the way through (2 and a 1/2) It SMOKES my mates Turbo Suzuki Baleno that has made a 168 fwkw and a high 13 sec pass. and he is nothing but light in the revision mirror. Please understand that the Baleno is at least 50-100 kilos lighter, and the AE82 is not tuned and has not been dyno-d. Have a look at www.tweakit.com.au serious potential.
