ronald_loulan
    26
Everything posted by ronald_loulan
  1. I hv a ke70,I'm thinking to increase turning radius..... Any idea...?? :dance:
  2. thanks guys.... I just replace the whole axle wif ke70 small square light... I though the diff r same but after i took it out,the diff r larger than mine... Then i change the whole axle n propeller shaft..... But the ratio n the same.... Y....?? Should the bigger diff hv different ratio....??
  3. I reccon my 4k and get bout 10L/100km.....
  4. I'm thinking to swap my fren`s ke30 wif my ke70`s differential gear or housing..... Can Pnp....?? Or not possible....?? How bout the gear ratio....??? Cheer...
  5. I found this a long time ago.... Engine Engine Displacement (cc): 1290 Firing Order: 1342 Spark Plugs Type: Denso W16EP Gap (mm): .80 Compression Pressure (psi): 127-156 Distributor Make: Bosch DWELL: 50±2 Point Gap (mm): .40-.50 Ignition Timing Initial/Static: 8@Idle C/S Fuel System Make/Type: Aisan Float Level (mm): 7.5 Idle Speed (rpm): 750N Emission CO%: 0.3-2.0 Fuel Pump Pressure (psi): 2.8-4.3 Fuel Capacity (cc/min@rpm): 900@5800 Oil Pressure (psi): >45@3000 Valve Clearances Inlet Hot/Cold (mm): .20 Exhaust Hot/Cold (mm): .30 Torque Specification Cylinder Head (ft.lbs): 39-47 Main Bearings (ft.lbs): 47-49 Con Rods (ft.lbs): 29-37
  6. I tested my 4k(carb) n the result r 140,135,130,150(psi)... I just overhaul the engine last month.... All stock,just the exhaust is diff... Is the test result good..??
  7. I wonder wats the price of petrol on other country...??
  8. 4k`s spec Ron 89+ oni arr.... I'm using ron 97 all the way....
  9. Can a Ta22 brake fit directly in Ke70....??
  10. Its an oil screen with the pump....(i think) :harhar:
  11. what result will i get if i put a 4k head in 5k block...? I search d but dun understand..... :ban:
  12. U guys got the 4k info....? I mean same info as the 3k pdf file....
  13. Any list how to do tat....?? Mine is 4k carb..... Really wanna do something diff....
  14. Thaknssss...... :jamie:
  15. Name: Ronald Location: Seri Kembangan,Selangor Phone no: 0126631991 Drive: 1982 Ke70 Occupation: Mechanic
  16. All if can.... :jamie:
  17. Can any1 giv more detail how to do tat...?? Thakns... :D
  18. Thanks........ :thumbsup:
  19. Any1 noe the best size of exhaust system 4 my 4k...? what kind of extractor is good...?? how many inch piping is the best...??
  20. thanks..... Anymore....??:)
  21. :sad: I oso need the KE70 wiring diagram... My RPM meter gone crazy.. When idling the RPM goes 2k but my normal rpm is just 1k.. If i press the brake the the rpm drop to normal again... I think is the earths problem... Any 1 can help....
  22. Aikss.... U ask me to search http://www.google.com or what...?? Dun understand.... :D
  23. 3k head can plug n play in 4k..?? The head gasket oso the same...?? Will this 3k head do any damage...??
  24. If my 4k i put 3k head tat mean my cr goes up,rite..?? U mean 8v 3k head..?? If cr up the the power up,isit...??
  25. Wanna noe tat what to mod if i put in the AE86 rear axle to my KE70... I heard tat is almost plug n play.... But some say need to mod the anti roll bar... Need to change the fuel tank or not...?? How about the Handbrake cable...?? :sad:
