Everything posted by maxyboy55
Dohc 4k?
what compression ratio did they end up getting?
Dohc 4k?
today i made water injection for my car (i know i am veering off subject a bit), and i want to make the compression ratio around 10:1 to 10.5:1 (ish) so if anyone has shaved a bit off there 4k head, how much did you take off and what compression ratio did it end up being? cheers
Dohc 4k?
you would be surprised, one of the guys i know there owns a honda CRX, 11.5:1(ish) compression ratio, 156hp @ the wheels, very fast i reackon i'll just stick with my good old 1300...
Dohc 4k?
what year and model are 4e-fe's out of?
Dohc 4k?
i've put electronic ignition out of a 5k in it and i noticed a little difference, then i got addicted... i see that in every ones opinion putting a dohc head on my 4k would be hard and annoying, but i'd like to do it (and potentialy make a 4kg-c)
Dohc 4k?
the problem with putting a 4age in is that i'd have to modify the engine mounts, have a new gearbox etc. the other main reson that i want to stick mith my old 4k block is that i want to start hillclimbing when i get better at driving and i don't really want to go up into the 1600's class, staying in the 1300's (that i think there is) so if anyone out there has a 4k block/motor and a 4age head/motor, and they could check the bolt pattern i would greatly appreciate it :(
Dohc 4k?
what i was going to do was take the 4k head off, make a new timing chain/find a belt, take the lifters out so the original cam is only driving the dizzy and put on a 4age head (for example). my dad ( a mechanic) and i had worked out this plan only this morning, so we're not too sure of what dohc, in-line 4 heads toyota make and what would have the same bolt pattern. it should work, if there is a head like that out there :( and by modified, i mean no engine enlargments, turbos, or anything that you would have to get an engineers certificate for
Dohc 4k?
With me only being 15 and the new laws in nsw saying that i couldn't drive around in a modified car, my dad suggested that i put a dohc head on my 4k, seeing as most other brands of engines can swap heads eg. subaru 2.5l with 2l and ford 1.8l and 2l heads i was wondering if there were a toyota head with dohc that would bolt straight up, without too many modifications. i was hoping that a 4age head would bolt up seing as they're relitivly cheap in comparison and would be easier to find max
