Everything posted by ca18ke20
4age Blacktop Ecu Pin Layouts & Wiring Diagrams
hi all i have just recently bought a ae82 with a blacktop 4age engine installed.the problem is that it has a auto gearbox and is driving me mad.I'm looking at converting it to manual but I'm not sure if the auto ecu will be ok to use with the manual gearbox. do i have to bridge anything out at the ecu in order for the standard ecu to work? i have been told that the auto and manual wiring harness plugs are different. any help with this would be greatly appreciated.
Ca18det Eng.mounts To Ke Crossmember
thanks for the info mate, the hopper stoper brake set up sounds like the way to go. i know they are heavy but a good brake set up is a must. id rather build my ke20 mate nothins more rewarding than building your own car. if i buy your rolla it wont be the same. good luck with the sale though.
thanks for that info mate, I'm rebuilding the hole car so every bush is going to be replaced, i like the idea of those brakes you have used. where abouts did u get them from.they sound a lot better than the s13 brakes and stuts i have. I'm building the motor for max hp so i need good brakes to stop.
thanks for that, ive ended up getting a s13 half cut so ive basicly got everything here from it. thinkin of usin a borg warner diff or just goin ford 9 inch.I'm planing on getting big times down the quarter mile with it. I'm in the process of moddifying the tunnel and minni tubbing it atm.
hey all I'm new to rollaclub, ive got a ke20 corolla, and I'm in the process of instaling a ca18det in it. ive noticed that a few of you have got corollas with ca's in the eng. bay. I'm wondering what eng. mounts did use use,did use modify the cross member or just make new brakets to sit the motor on to the mounts?any pics would be a great help to me. plus any info on brake/suspension upgrades would be helpful. thanks.
