Kaz
Everything posted by Kaz
  1. there's a 4 pin circular connector on the compressor, i tested the pins inside that and didn't get any voltage. however there are 2 other connectors coming off the compressor, one has a single wire and the other had two wires - i wasn't able to disconnect them to test.
  2. All the fan speeds work. I've checked this 30A fuse, and it seems to be fine. I'm not sure about the relays, i can't hear them clicking. As you can see the on/off light turns on with the button. is there anything else i can check?
  3. Just been having problems with the A/C lately. After pressing either the A/C button or ECON button there's no sign of the A/C compressor turning on. No fluctuation in the rev's, can't hear the compressor. Does anyone know what the problem is? also, is there a downloadable Technical Manual? Cheers Edit. Just wanna clarify that its an AE100 Corolla.
  4. Hey, how you going guys. I've got a AE100 Corolla (Import). Reverse lights are not lighting up. At the same time the reverse gear status light on the dash is not lighting up and reverse warning tone is not beeping anymore. Could it all be linked together?
