Garagedefend
    8
Recent Profile Visitors
1551779 profile views
Garagedefend's Achievements
  1. Really love this car. I have a 118 wagon in white and my plans were the same as yours. watanabes with over fenders lol
  2. yeah mate just waiting on missus to get home lol cheers
  3. hey mate still keen on my car?
  4. Problem fixed :lolcry: jiggled wires, cleaned housings/fuse holders and replaced busted fuse. All is well again :)
  5. Forgot to mention my horn died too. Replaced fuse today, cleaned sockets with bristle and the rear brake lights work now when I step on the pedal. The reverse lights work too. AND the hazards work. However now the rear brake lights don't turn on when I turn the park lights on. I checked the bulb and the filament is still on and connected. however seems a bit bubbly on the sides so might have already burnt out. Will just buy bulbs later on and hope thats the last of my problems. My front parkers don't work still as well. may need a bulb as I found for some reason I've got double contacts on mine. lol the low light is burnt out so thats probably it
  6. I'm guessing. First thing I'm gonna try and check is the fuse. Cause if it was just the brake lights that turned off I would be suspicious of it. But since the park lights and reverse lights as well as my hazards died. It might be a fuse. IIRC in most cars there are all connected together to one fuse line. hope that works! thanks man! and if neither work I will have to try and find out if its earthing. It was all fine till this morning :lolcry:
  7. hey all, my ke55's brake lights,reverse lights and hazard lights were working fine this morning however i noticed now that they don't work. When I turn on the park lights the tail lights work. When I indicate to one corner they work. however when I go into reverse, step on the brake pedal and turn my hazard on, none of them work. I also noticed that my front park lights have died. I had a look under the dash and all the fuses are intact. I had a look and in the engine compartment theres a fuse that has a wire going to the horn. Just one fuse. The fuse on that is blown ( I didnt notice if it was okay before) you guys rekon that one fuse can be causing all this? will try and change it later and if it doesnt work I'm pretty much stumped. cliffs: when I step on the brake pedal the lights don't work when I turn the park lights and headlights on the rear brake park lamp turns on with the headlights however the brake lights (when pedal is stepped on) and the front park lights remain off when I indicate to either left or right, the front and rear indicator works. However when I turn my hazards on, none of them work when I put it in reverse the reverse light doesnt come up. halp me pls lol Thanks! :lolcry:
  8. managed to fix mine :) just re did the wires to the dash
  9. I seem to have this problem sometimes. Although mostly only now when its cold and when the engine is warm its a bit better. Sometimes whilst the car is on the chg light comes on and my fuel/temp drop down to where it would be if the engine is off. Never experienced it whilst driving though. happens sometimes when the car is stationary. Also sometimes I notice when I turn the car off for a bit then turn it on, the gauge wont light up but it starts. if I shut it off and re do it it starts fine afterwards. and during cold starts the chg light stays on but fades away anyway after a while so I suppose thats normal. I'm guessing its the connection around the gauge that plays up?
  10. hay guise. I'm in act for the holidays and I'm in belco. I bought a ke55 though. white, 4k stocker with 4 speed lol
