JRADSTRX
    93
Everything posted by JRADSTRX
  1. hey guys i know i havent been on here for a while, and was quite annoying at times but now i have a build that is actually going somewhere i have a RT142 Corona with a sr20det in it its only a track hack/missile but still have a decent car to be proud of ENGINE s13 sr20det redtop stock as a rock running 10 pound and a front mount and nistune ecu SUSPENSION AND WHEELS front s13 coilovers rear 6kg springs with short stroke shocks r31 front lower control arms t series toyota diff with 4.11 gears and lsd(LOCKED STANDARD DIFF) aha 15 x 8 - 9 steelies on front and whatever on the back for skids :) INTERIOR bride fixed back seat on custom rail appropriate guages hydro handbrake 4point harness so there it is
  2. thanks also
  3. easy mate thanks! :)
  4. what are the s series? Need a model car so i can find one :)
  5. anyone?
  6. Whats the reasonin for the thermostatic valve may i ask? Or is the only relavent to street use cars and not track cars where you would intentionally warm the car up to full operating temp before drivin?
  7. I'm running a Sr in a corona but all i need to know is what tailshaft to get so i can but the rear yoke off for a custom tailshaft to be made :) also i believe that the diff i hav is out of a celiba but i know what model! So all help would be appreciated :)
  8. hey guys! Ive got a t series diff what tailshaft do i need to suit the diff Flange? Just need the flange part cause I'm gettin a tailshaft made to suit my car
  9. Yeh mate its all good! One mount might hav a slight bend or flex to the rubber but its ever so slight. Took the motor out to put clutch and gbox on! Should be back in tonight if all goes well! So hopefully pics tonight :) but don't rely on that Aha
  10. Aha your an idiot :) Aha Ill hopefully hav a pic up later today!
  11. to all the people that said it wonT bolt in it does! Just needed to make a plate to go across the mounts on the crossmember! Will post a pic later :)
  12. to all the people that said it wonT bolt in it does! Just needed to make a plate to go across the mounts on the crossmember! Will post a pic later :)
  13. yes i hav already done suspension, thinkin hilux or r31 diff so i am not stupid, I'm just asking there questions before i start doin it so i know what there is to do and not to do if you get what i mean Thankyou for the nice comments about Sr20det's :)
  14. and i don't want the weight of a 6cyl, I'm building a using it as a drift car so don't want it to drive live a boat
  15. yeh thanks for the help guys gathered that this stuff would be needed to do but i just thought id ask as some engines bolt into other cars straight. i thought about 1ggte but i love the sound and performance of the sr20 and I'm a corona man, and love my corona, so thought as well i should put the two together :) cheers
  16. hey guys, i have a rt142 corona with a blown up 22re, its my track car and I'm looking at putting a sr20det into it! i was wondering if anyone could help out in whether the engine mounts on the crossmember with bolt up to the sr20det or will i have to make new mounts cheers jaryd
  17. on a rt142! Want to know cause I'm a fitter turner and Ill be makin myself a lock spacer
  18. hey guys need to know what size thread the rack ends are! The part that screws into the steering rack! I need to know the pitch off the thread too! Cheers Jaryd
  19. cheers for all your help guys sorry for late reply hav been busy but thanks for your replys, looks like ill try tieing them :)
  20. hey guys as the title of the topic states were can i get my distributor centre welded up for a 22re turbo motor? cheers
  21. cheers mate!
  22. hey guys as the title states will a ke70 diff fit into a rt142 corona which has the solid rear end?
  23. anyone?
  24. does anyone know whether ke70 or 86 swaybars fit a rt142 corona with solid rear end?
  25. Ahk!
