JRADSTRX
    93
Everything posted by JRADSTRX
  1. its an rt142 with a solid axle.. Non irs model!
  2. as the title states mini spools! Where can i get on in adelaide for my corona diff? Not sure on what series diff it is. But where?
  3. sick! Will probably be there!
  4. sick! Will probably be there!
  5. does an entry fee occur for people just doin the cruise? Would love to come out for a cruise!
  6. does an entry fee occur for people just doin the cruise? Would love to come out for a cruise!
  7. yeh guessed that sleeve kit was easiest. cheers
  8. hey guys know this isnt a corona forum but! Does anyone know what coilovers can be fitted into then without to much hassle?
  9. do you run brakes in this thing.. don't see no booster in it..
  10. $50.00 dollars, bit af a lowballer when it says $1000.00 :dance:
  11. without actually seeing any pictures i can't make a proper judgment but i would just get a re-hone done on all cylinders and clean it up really well.. should be fine if your looking for a new engine anyway and maybe get some harder rings.. if thats possible
  12. thats what i thought.. i don't actually have a turbo car it was just gettin to me reading one thing and then another.. many more opinions welcomed...
  13. hey guys.. its got me stuck.. people say yes its bad and no its ok.. is compressor surge actually bad for your turbo or is it just a myth.. I'm guessing its not good cause its trying to turn the turbo the opposite way its spinning.. cheers
  14. don't forget the earthing.. i cnt memba.. but don't earth it to a cetain part or sumthing and stuff all your bearings up..
  15. ok.. ill go with cutting.. i just thought i should ask cost its an easier option just coz i dnt have to take the strut out and shit.. ill go with cutting.. cheers guys for the help.. thankz
  16. ok.. how do i heat up the spring to lower it.. i know you can use a blow torch to heat up a couple coils and then let the car down and it will stay that way.. but how? cheers
  17. i know cuttting is bad.. its only for a learning curve thing.. ive never done it.. so i want to.. cheers
  18. ok thankz.. so i will need spring compressors.. if i cut them when there in there.. what will happen? just curious..
  19. hey guys.. to cut springs in a mcpherson strut arrangement do i need to use spring compressors to get the spring out.. or can i do it without the spring compressor? cheers
  20. A J P S sell them for $440 a set.. cheers
  21. thankz guys.. i thought it was just that i took the muffler off.. ill prob just get a hot dog and a tip and stick it in the spot of the muffler.. it screams it tits off under full noise :dance: cheers p.s. thanks seabiscuit for sticking up for me.. i know it was a stupid question.. but it had to b asked to confirm
  22. Hey guys.. just a quick question.. on a std exhaust for a ke70 with a 4k it has a middle resonator and end muffler.. i took the rear muffler off and its fukn loud.. why is that?.. and i think it needs the flange gasket replace(manifold to pipe gasket).. in doing that will it quieten things up? a little bit.. cheers
  23. yeh doing that to.. bought flush and coolant, both of which have to be made up..
  24. coz i got stuff i have to mix up and make my self, so i need to know how much to make, i might jst make up 4litres and the put it in.. cheers
  25. as topic states, how big is the cooling system in a 4k in liter's? cheers jaryd
