Hi guys, am looking at putting some gauges in and have a few questions, i was wondering if any of you have any advice.
Probably looking at oil pressure, oil temp, volts, and maybe air/fuel.
Have had a bit of a look online about installing the oil gauges and they mention an "oil filter sandwich plate" which is kinda like a spacer plate between the motow and oil filter with 2 blank sensor holes in it. Has any of you put one in? Do they work? Ive heard of erratic idling and pressure afterwards.
Volt gauge is no problem. Put one in before. Piece of cake.
Air/fuel apparently only works effectivly if you have a wideband sensor. Is it worth it if its only the narrowband sensor? I have an AE112. 7A-FE motor.
Any help/advice would be greatly appreciated.
