Hi all ive just replaced the front brake pads on father in laws corolla
Is it common on the ae102 r for the discs not to be attached in anyway except wheel hub nuts and the centre hub flange
Ive never seen a brake disc that just slides onto the centre hub and has hub bolt holes with a mil of clearance either side but no screws there are two threaded holes in the disc that i would have thought at least keep the disc attached to the hub
I'm usually involved in french cars which have a pair of equie distant posidrive screws to secure the disc plus wheel bolts that screw into the hub plus the hub flange
Would the brains trust please enlighten me as I'm a little concerned about how safe this set up is
