Search the Community
Showing results for tags 'lower control arm'.
Hi, wondering if anyone could tell me the length of ke20 and ke30 LCA lengths? (Centre of ball joint to centre of bushing) also want to know if a ke20 ball joint will fit into ke30 LCA? And if ke20 caster arms and sway bar link bolt in to the ke30 lower arms? basically wanna use the aftermarket T3 ke30 LCA’s in my ke20 https://technotoytuning.com/toyota/ke30/front-lower-control-arms-ae71ke70ke30-corolla cheers.
Hi, I need to replace the lower control arm bushes on a KE55. Workshops charge you a fortune to do the job. Is it really a pita for an average skilled person to do the job himself? (I am not an expert mechanic, but I replaced the rear shocks, bushes and leaf springs myself with no problems). Is it necessary to completely remove the LCA from the car? DO the old bushes came off easy? Is a press really needed to fit the new bushes, or a bolt, a pair of large washers and a bit of patience can also do the job? Any advice is really appreciated.
- 3 replies
- KE55
- lower control arm
(and 1 more)
Tagged with:
