October 11, 200620 yr comment_145975 Gday all just chasing some info from you AE freaks. I just bought a 92 AE92 twin cam with a stuffed clutch and have a AE82 hatch sitting here for bits and would like to know if the box and clutch are interchangeable?? Havent done a FWD clutch yet but I'm sure theyre the same as all other Corolla jobs, easy when youve done a couple. Cheers, Andy. Report
October 12, 200620 yr comment_146070 ok, if they are both 4AGE motors, than the gearboxes will both be the C52 5 speed. The gearbox it self should go in no worries, HOWEVER, the flywheels are both different sizes between the AE82 (bigport) and the AE92 (smallport) motors. I think the measurement are around 425mm vs 415mm, but i realy wouldnt know. Do a quik search on Twincam.org and you will find out soon enuff :y: The gearboxs should be fully interchangable, aslong as you keep the appropriate flywheel, ie. if you put the AE82 g/box onto the AE92, makesure you keep the AE92 fly wjheel NOT the AE82 one :P Report
October 12, 200620 yr comment_146084 flywheels arnt an issue use the clutch to suit the flywheel easy as when swapping boxes check the starter motor bulges. if you have a one bulge and try and fit a two bulge it may interfere with the water pipes Report
October 15, 200620 yr Author comment_146642 OK what I've got is an 87 hatch with a 4A single cam and a 92 Seca twin cam. Can I take the clutch out of the hatch and put it in the Seca or is a twin cam clutch different to the earlier single cam clutches?? I havent played with AE mechanicals yet. Report
October 15, 200620 yr comment_146643 i THINK so. but i can't recall the size of the 4a flywheel for the effort involved just get a new clutch. they are cheap and a 2nd hand clucth is just silly Report
October 27, 200818 yr comment_284998 By 4ac single cam you mean 4AC? if so then it has a 6 bolt flywheel and is like a 200mm clutch, while the ae92 will have a 212mm or 215mm clutch and 8 bolts on the flywheel. So I don't think you can interchange them. I think that's answering the question lol. shit just realised its an ancient thread... oops lol Edited October 27, 200818 yr by quadeyquade Report
