October 25, 200620 yr comment_148125 After all the other dramas I had, the starter motor sometimes simply clicks. I put in a 2nd hand starter motor but it does the same thing. I have disconnected and checked all connections. Has anyone ever had the ignition switch play games? I am wondering if that last little bit (start) in the iggy switch is dead or dying. Has anyone had this problem? Is it common? If it is I will simply reroute wires and put in a starter button like my old FJ. Cheers, Pauo Report
October 25, 200620 yr comment_148128 Ah the common k-motor starter problem. Really easy fix mate. Just wire in a relay to the starter motor solenoid and you'll never have the problem again. The wire toyota ran originally must be pretty crap cause ive had to do it too 2 of my corollas. Good luck mate :) Report
October 16, 200719 yr comment_203608 pfft, just run a brand new wire, and crank the old push button start, easy as piss. Report
October 16, 200719 yr comment_203623 If it is I will simply reroute wires and put in a starter button like my old FJ. Cheers, Pauo Don't forget that the start circuit also gives a 12 volt boost to the ignition coil while cranking. with a new starter button switch it may start with a fully charged battery, but if the battery is down it probably wont start as the coil voltage to the coil thru the ballast resister when cranking would only be about 4 volts. Edited October 16, 200719 yr by KE30_KE35_KE55 Report
