zach Posted November 5, 2006 Report Posted November 5, 2006 I was just wandering if anyone knew what brakes come standard on a 74' Ke20 coupe? and what you could upgrade these to? and if prices are known for this? thanks alot for the help. Quote
Raven Posted November 5, 2006 Report Posted November 5, 2006 If you have time and money, you could replace the complete front strut with something offa celica (RA40 or RA60). Would just need custom springs as you'd have to use the KE20 strut tops with the RA40 or 60 Celica strut. Or you do a coil-over conversion on the celica strut which is what I'm doing. Will cost you around 600 without adjustable camber/castor tops. Quote
Redwarf Posted November 5, 2006 Report Posted November 5, 2006 The simplest and easiest upgrade is to put KE55 discs onto your existing KE20 hubs. Oversize and tap four holes for the backing plates and everything bolts in. Cost is a set of rotors and calipers from your friendly wrecker, plus rebuild kit. Quote
