November 26, 200619 yr comment_152396 hey guys, AE82 SOHC carbie. 4A-C i just took it for a run around the track today (it was the last one, I'm goin on holidays for 8 weeks on wednesday so i figured why not) previous to racing it, i changed the oil and filter, checked all the plugs (didnt replace em tho) and just basically checked it over mechanically. after doing a few laps (4 or 5) it started heating up (stock standard, u kind of have to expect that) so i pulled it in. popped the bonnet and let it cool down. i noticed some oil dripping from effectively underneath the brake booster (not coming from there though) it was dripping off the mudflap. I did overfill the oil a little bit so I'm hoping it could just be that. after that i took it out again. another 4 laps and then on my final one it seemed to just drop in power. no acceleration, and sounded a bit deeper. it doesnt seem to backfire though. i brought it in, let it cool again. i can't remember any particular point where it jerked or did anything strange i took it out one more time and only managed to get to 120kmhr down the straight. previous to that i managed 140kmhr down the straight on every lap. i still have plenty of oil (while it was hot) but it was very very thin. (liquid) will check it again when it cools down. any ideas as to what i did? Cheers, Tim Report
November 27, 200619 yr Author comment_152650 so i guess no help? I'm guessing a comp issue so ill check that eventually. I'm goin on holidays for 2 months so i will deal with it when i get back. Report
November 27, 200619 yr comment_152659 Intake issue perhaps? Or you could be right and the head gasket might have failed. I'm useless when it comes to trouble shooting. Report
November 28, 200619 yr Author comment_152820 trouble shootings fun :y: ..... especially when u plug the HT lead back in and it runs on all 4 cylinders again........................................................................... . Report
November 29, 200619 yr comment_152869 I almost said high tension, but it didn't seem right. Don't worry, you're not the only one to go racing at Hidden Valley and get a very small issue that you mistook for a big one. I've had a loose coil wire that made the engine drop two cylinders, which I thought might have been a mechanical issue. And don't get me started on the f**king intercooler piping. Report
November 29, 200619 yr Author comment_152874 lol. yeah, that was the issue. dad said check the plugs which seemed likely. so the next day i took off the HT lead on no.3 cyl from the plug and it came free completely (as in from the dizzy end as well) so i took out the plug, it seemed fine, put it back in connected it up and realised that i didnt remember if it was connected to the dizzy in the first place. so i connected it up and started it up. suprise suprise. it was fine. :y: adam. what happened with the intercooler piping? :y: Report
November 29, 200619 yr comment_152875 The intercooler needs another mount made as it can move on the ones on the cam cover. It works the intercooler piping off, meaning that I'm trying to run the engine like a naturally aspirated motor with low compression and a compressor causing drag on the motor with no benefit. The last time it happened, instead of the above happening, it acted like it had a wide open throttle, as the intercooler is after the throttle body, so there's nothing to shut the intake off. Report
