February 8, 200719 yr comment_163153 hey more questions again on to vacume noodles, Spaghettios pic is real useful but egr-v, vsv, vcv, vtv, v s/w, I'm confused (which is easy) so can anyone help identify them does anyone know where to find more noodles and t connectors i was thinking about clarke rubber Report
February 8, 200719 yr comment_163160 My Repco store has shit loads of T peices and hose and shit so maybe check your local shop out ? Report
February 8, 200719 yr comment_163166 if u look at the diagram. which I'm sure i have posted up before. but ill find the link to it in just a moment, you will notice that the diagram actually has the picture with a technical picture. so you can work out which is which. Report
February 8, 200719 yr comment_163178 http://www.rollaclub.com/faq/index.php?tit...stem_%284K-C%29 in the faq. i searched everywhere before resorting to google. geeze I'm dopey... anywho... i believe my one, is the bottom one. ok, from left to right in your pic... 1. one way valve (try blowing down it to work out which way it flows. if both. it f@$ked) 2. looks like VCV to me closer to the carby 3. dunno, ur the numnuts that took it all off... 4. VTV i think. should have an A on oneside and a B on the other. as per diagram. 5. dunno, u have to do some ofthe work 6. looks like VCV to me closer to EGRV used my diagram: http://www.rollaclub.com/faq/index.php?tit...mage:Vacuum.jpg good luck ;) Report
February 8, 200719 yr comment_163201 It's all on the FAQ http://www.rollaclub.com/faq/index.php?tit...stem_Components http://www.rollaclub.com/faq/index.php?title=Abbreviations Report
February 9, 200719 yr Author comment_163299 thanks guys the guy i had bought it off had connected them randomly, and i want to get it running legit but I'm still missing stuff Is close enough good enough? Report
February 9, 200719 yr comment_163317 all you need is vac advance and charcoal canister lines connected. the rest you can plug up. makes it much neater and increased my fuel economy! (note: this may also be due to a fixed vac leak, carby kit, and retune) Report
