When I push the clutch in on my DX, to stop at the lights, it just seems to die. I have to pull the choke on it a bit to make it idle, but after ive pulled the choke out it will idle again without dieing... do you guys have any idea what is causing this? :lolcry:
mine does the same thing man, i fixed up the timing which helped it a little but sometimes still does it, though i havent had a service in ages. so I'm due for a fine tune and service which will fix everyhting up
It went to the garage and got fixed last time but now its started to do it again :lolcry:
Oh, check all your vacuum hoses too.
If any are split or have come off your car will stall due to not holding any vacuum.
  • 4 weeks later...
