DXWag Posted February 21, 2007 Report Share Posted February 21, 2007 When I push the clutch in on my DX, to stop at the lights, it just seems to die. I have to pull the choke on it a bit to make it idle, but after ive pulled the choke out it will idle again without dieing... do you guys have any idea what is causing this? :lolcry: Quote Link to comment Share on other sites More sharing options...
Raven Posted February 21, 2007 Report Share Posted February 21, 2007 Yeah, you need to up the idle on the car so it doesnt die. When was the last time it had a service and tune? Quote Link to comment Share on other sites More sharing options...
ae71_drifta Posted February 22, 2007 Report Share Posted February 22, 2007 mine does the same thing man, i fixed up the timing which helped it a little but sometimes still does it, though i havent had a service in ages. so I'm due for a fine tune and service which will fix everyhting up Quote Link to comment Share on other sites More sharing options...
DXWag Posted February 22, 2007 Author Report Share Posted February 22, 2007 mine does the same thing man, i fixed up the timing which helped it a little but sometimes still does it, though i havent had a service in ages. so I'm due for a fine tune and service which will fix everyhting up It went to the garage and got fixed last time but now its started to do it again :lolcry: Quote Link to comment Share on other sites More sharing options...
Raven Posted February 22, 2007 Report Share Posted February 22, 2007 Oh, check all your vacuum hoses too. If any are split or have come off your car will stall due to not holding any vacuum. Quote Link to comment Share on other sites More sharing options...
andro0o Posted March 21, 2007 Report Share Posted March 21, 2007 I'm guessing vacuum leak..? Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted March 21, 2007 Report Share Posted March 21, 2007 electronic ignition or points?, if it's points they may have closed up. Quote Link to comment Share on other sites More sharing options...
