the horn in my beast is starting to annoy me ... when i'm sitting still or just rolling slowly the horn will work (sometimes) but in any other instance it just wont work. has anyone had this problem before that can help. i've run along the wiring and can't find any loose or brocken connections that i can see
I had a similar problem years ago. The Metal plate behind the steering wheel was warped. The spring loaded plunger that contacts the plate was also worn down. So the connection was being broken as the wheel was rotated.
From memory i just straightened the metal plate, and replaced the spring loaded plunger. Not sure if the plunger is fixed solid to indicator stalk assembly though. I may have just replaced the whole stalk assembly.
Edited by kangaroosa
