have you tryed leaning it slightly..? like 1/4-1/2 a turn..?
Yes, I have adjusted the idle mixture and the idle speed screws accordingly to get a nice consistant idle speed. At the moment, the idle speed is set a bit higher because it helps keeps the revs up during the colder weather here. Sits around 1500rpm when the car is warm, so it is just a little bit to high. Going to the carbie bloke tomorrow to get some new jets for it, so that should make it run smoother.
@smacko84 "oh wtf a loose plug..?" Gold :y:
