August 4, 200719 yr comment_190253 hiya, I wondered if I've done something...when I was logged in earlier today (5.00m ish) the forum all looked fine, here I am back at 10pm and the first post in each of the sections is ok, but then each post is a link, you can't scroll down and see all of them...have I done something or is it a new thing??? Cause I don't like it :D Lesley :o Report
August 4, 200719 yr comment_190256 Click on options (in the title bar of the thread, right hand side, drop down menu) and make sure it says under Display Modes "Standard" in bold. If it doesn't, click on Switch to: Standard. Report
August 4, 200719 yr comment_190257 Have you got into the Lo-fi section? It tends to make everything, err... simple. If you are, you should be able to press a button somewhere to get you back to normal. I think. :o That's all I can think of, but them I'm not the most technologically minded individual. FWIW mine works fine. :D *edit* Ben beat me to it. But then again, it did take me 20 minutes to type it. Edited August 4, 200719 yr by Redwarf Report
August 5, 200719 yr Author comment_190394 ok, I was having a blonde moment...I've figured it out, have NO idea how I managed to change it in the first place :o it's all back to normal, *back in the comfy chair* :D Report
