nedic Posted August 14, 2007 Report Share Posted August 14, 2007 hey guys, ive just fitted my new 3/8 bundy tube line no dramas, however what my question is, should i change in the inlet and outlet fitting on the fuel tank so that they match the same size as my fuel lines, or will it be ok as ive got a surge tank and the fuel that goes from the motor will be going from the fuel tank. cheers thanks in advance Quote Link to comment Share on other sites More sharing options...
ca18rolla Posted August 20, 2007 Report Share Posted August 20, 2007 hey guys, ive just fitted my new 3/8 bundy tube line no dramas, however what my question is, should i change in the inlet and outlet fitting on the fuel tank so that they match the same size as my fuel lines, or will it be ok as ive got a surge tank and the fuel that goes from the motor will be going from the fuel tank. cheers thanks in advance use the orignal supply line for the return and if the surge tank is full there is no need to change the outlet from the tank to the surge, I used a screw tail fiting in the tank and some 10 mm fuel line to the pre filter yhen fuel pump Quote Link to comment Share on other sites More sharing options...
