Auto To Manual Conversion
Hi There,
I have a Ke10 with a 4K motor in it. Currently it is running the toyoglide 2 speed auto box. :wink:
I am going to do the manual conversion however I wanted to double check that I had all the parts that I need. Also any hits/tricks that you can let me know about would be appreciated.
I currently have a 4 speed box (K40).
Part I believe I need:
KE1* pedal assembly
KE1* clutch cable
flywheel off a 4 speed box - do the 4 and 5 speed use the same?
Tail shaft - I assume that I need a KE1* 4 speed tail shaft or can I get one out of a ke2* series?
Some mates + Beer and a weekend of friggin about under the car.
I believe that I need to cut back the transmission tunnel as the gear leaver position is further set back than the auto. Does anyone know by how much? or is it a matter of try and see?
Is there any modification required for the cross memeber that the gearbox sits on? or is it easier to try to source a cross member from a manual ke1* model?
I was thinking initially I will not swap out the diff centre.
Any help or advice would be greatly appreciated.
Anthony
hey there mate,
okey doke,
-pedal assembly, yes
-clutch cable, yes
-just a manual flywheel, they are both the same between 4 & 5 speeds
-just use the 2 speed toyoglide tailshaft, as it will fit the manual box( 2 speed auto and 4 speed boxes are both the same length and output shaft spline)
-gearbox crossmember and mount are both the same between auto and manual
- and last of all its just a matter of try and see when it comes to the shifter hole
hope this helps mate!
cheers, phatke30!
Thanks for the info!!!!
Looks like I am set for all the parts then. I was unsure about the tailshaft but that is tops news....
Anthony
