David[RL] Posted October 1, 2004 Report Posted October 1, 2004 (edited) I'm planning to buy a 2T-B and a T50 gearbox for my ke70 I also have a 4A-GE in my garage I'm not using, but I don't have the engine mounts and I don't want to use EFI.. ( to much work to change ) Does the 2T-B exhaust manifold mount on my 4A-GE without much work? and can I use the carburettors/ inlet manifold from the 2T-B on my 4A-GE? and the engine mounts, hard to make? can I use the 4k engine mounts if I modified them some? someone have any ideas what I should do? ;) PS: does anyone wanna sell their mikuni - solex carburettors with 4A inlet manifold? and some engine mounts? ;) Edited October 1, 2004 by David Quote
irokin Posted October 2, 2004 Report Posted October 2, 2004 Easiest way to fit a 4A-GE into a KE70 is to find an AE71 cross member. Its all bolt in from there. Intake and exhaust from 2T-B are not interchangeable with the 4A-G. The only carbys I see for 4A-Gs are Dual Side draft DOCE webers...and they cost upwards of $500 Quote
David[RL] Posted October 2, 2004 Author Report Posted October 2, 2004 hmm, so I can not make my 4k / 2T-B engine mounts fit to the 4A-GE at all? it's hard to find 4A engine mounts here in norway.. anyone have a spare you want to sell? ;) and manifolds to the 2T can't be fitted to the 4A at all either? ;) can I use the exhaust manifold from a ae92/ae82 with 4A-GE? these are the only one that have 4A-GE engines at the wreckers here in norway, and even they are difficult to find.. ;) Quote
irokin Posted October 2, 2004 Report Posted October 2, 2004 Nah can't use the AE82/92 because theyre FWD and will be sending the pipes under the engine. Intake manifolds I'm sure wont fit, exhaust are the only ones youd have a chance with but I think your chances are slim. Engine mounts I don't know about...you would just have to try but I don't like your chances.... Quote
David[RL] Posted October 2, 2004 Author Report Posted October 2, 2004 Ok then, thanks for the help anyway.. someone wants to sell me some carbys with or without manifold to a 4A-GE, 4A-GE engine mounts and exhaust manifold? ;) Quote
