September 17, 200719 yr comment_198269 What are peoples thoughts on aftermarket cams in a 20V? It seems the biggest size one can go while retaining VVT is 264. Just trying to get a few opinions as to either get 264cams and keep VVT or scrap vvt and go larger? Cheers Report
September 19, 200719 yr comment_198711 i belive you only change the exhaust cam and just keep the standard cam with the vvt Report
September 19, 200719 yr comment_198734 Yep, you could always go a mixed duration set, some people get some really good results. I reakon maybe a 264 on the inlet to keep your VVT and a little bit of bottom end power, and a 288 on the exhaust side for shits and giggles. Report
September 19, 200719 yr Author comment_198736 With that set up I would only get one adjustable cam gear yeah for the exhaust? Cheers for the advice Report
September 19, 200719 yr comment_198757 Yep, I reakon you'd probably get away with one cam gear, but an adjustable one on the inlet would help fine tune where your power comes on. Report
