4age Into Ke70
ive done a 4age into a ke55... is there much difference? will a ae86 x member fit in it? any advice will help... and yep i have read alot of articles but i want full detailed ones so if you point me that direction awesome....
cheers
This is what you need.
Ae86/ae71 engine cross member
Ae86/ae71 gearbox cross member.
Ae71 manual pedal box with hydraulic clutch master cylinder.
Ae71 metal clutch line that goes around the back of the motor.
Ae86/ae71 metal engine mounts that bolt to the motor itself.
ae86/ae71 rubber engine mounts.
Ae86/ae71 gearbox stays (optional).
Ae86/ae71 sandwich plate.
All bolt in affair.
Ae86/ae71 engine cross member. soon to get in hold of
Ae86/ae71 gearbox cross member. X
Ae71 manual pedal box with hydraulic clutch master cylinder. how much?
Ae71 metal clutch line that goes around the back of the motor. how much?
Ae86/ae71 metal engine mounts that bolt to the motor itself. X
ae86/ae71 rubber engine mounts. X
Ae86/ae71 gearbox stays (optional). how much?
Ae86/ae71 sandwich plate. how much?
All bolt in affair.
everything marked in X is what i got.
roughly how much for the rest
Edited by kermit55
Well i paid $200 for
1X AE71 pedal box
1X AE86 engine cross member
1X AE86 gearbox cross member
1X slave cylinder
1X steel clutch line
1X master cylinder
For what you need, $150 tops for all of it.
1X AE71 pedal box
1X slave cylinder
1X master cylinder
do you reckon the toyota wreckers will have all of that. I'm from the gold coast
