hey my ke55 wont turn over. . i was looking around and found that my power cable from starter to battery had burnt thou some how, so i replaced this it put it all back on with difficulty and now still nothing. everything else works but no start.
Is the the starter motor is screwed or my alternator everyone i talk to has different opions.
Hope yous can help me
Replace the ground from the body to the block. Then replace the ground from the negative battery terminal to the car body. Then test the trigger wire on the starter. This is the small one that links the starter to the ignition via the harness. It should have 12 volts or more. If it doesn't, then you may have a bad ground or bad contacts in the ignition switch. If you have a bad ground you will still hear the starter solenoid click, but it wont have any power to turn the car over. Just went through all this myself over the last couple of weeks. Also, you can test the alternator by rollstarting the car, then parking it and using your multimeter accross the battery terminals, as if you were testing the battery. It should be no more than about 13-14.5 volts. If it is higher then you may have a f@$ked regulator on the alternator and you may be cooking your battery.
i cleaned up both grounds. . still nothing, I'm off to super cheap now to get some thinngs weill give it more when i get bacck
took my starter motor out today. . took it local wrecker today they said its all good so took it home but can't get it back in so il have to take headers off to get room to fit it back. . i also found out that my engine fuse was blown. . so hope all goes well tomoro with takers headers out and puttin it back in :)
