ay... i got a ke30 1977.. my stock diff is making some bad noises... liek a very violent ratle.. i think some one said something botu a bearing housing but I'm not sure......
let me know cheers
cants say it does lol... I'm down in S.A...
will i need everythign like axles etc? or just the bits n piece in the diff housing?? i don't know a whoel lot about cars.... :)
thanks cam
yeah if you havent done much with cars or diffs the easiest fix is to undo a matching rear end
from the wreckers, it come out whole, with drums and axles and centre all together.
- undo leaf mounts, tailshaft, brake cables, wheels, shocks etc (also take any of these if you need them)
then undo your old rear end the same way
then bolt up the one you picked up at a wreckers earlier and put on all the gear you took off or disconnected.
make sure the breather bit is on top when transporting the new diff to avoid an oil spill .
then drain the oil of the new one and fill with new diff oil, make sure the filler plug comes out
first then drain (else if it doesnt you will drain and can't refill!)
you can get special pumps or use a long bit of hose with funnel and friend to refill.
it doesnt get easier than that!
Edited by styler
