corolln
  1. ok cheers mate yeah there all different sizes inner and outer.. buy a drift? is that just like a gig of some sort?? one of the new bearing has light damage marks on the inside use it or buy the bearings? thanks
  2. hey mate a got a few laying round if u still need one pm the thread sizes etc.. ill post one to ya FREE. cheers bro
  3. hey guys, another problems.. I'm biulding up my 2tg (first engine build) I'm installing the aux shaft bearings, i know that are number etc. do you put them on the shaft and get them in that way casue thats not working the bearing isnt tight enough on the shaft to tight to get into its position in the block.. hope that makes sense.. any help will be great cheers,
  4. any one got the cost of the bearing btw?? cheers
  5. cheers guys yeah ill replace it soon.. gettin to annoying.. and its a t50 anyone got any ideas?? 2 of my gearbox mount bolts have threaded on my ta22.. any ideas?? cheers guys
  6. hey, my input shaft bearing has gone.. how long can it last like that does it do any damage to anything? cheers guys
  7. hey guys, is the fly wheel and clutch/plate the same used on the 2t wanting to put 2tg gear on to 2t.. cheers
  8. does it come with any rego or can be regod over the net? if u still got it any chance of a look this week.. cheers mate
  9. well i can get my hand on a 4age with box and run twin carbs off it have manifolds etc. what required to fit in a kp36 publica? mounts, will i need custom made tailsahft etc? will cross member be fine? only really want to spend 3g max on the car. not including car cost
  10. sweet your from adelaide. where about did you get the rebuild done? would you recommend the 5k or go a 4k only cause of avalibility??
  11. hey guys thinking bout buyin another rolla/toyota. 5k how much rwkw u able to get out of these things with say 2g spent on it. not include motor box etc. twim carbies head work, reground cam etc etc.... its either 5k or spend a bit more and going 4age NA.. the car is still undecided.. either ke20, 36 or KP36 publica. cheers guys.
  12. man just wack blocks in back n cut the front spring like 2 coils or u can put falcon spring in which will stiffin it up just make sure u get spring which are same diameter. or u can buy heavy duty springs for bout 150 blocks from r 80 bucks form autobarn
  13. hey fellas... ive put blocks in the back but now its time for the front. instead of buyin new springs lowered. what else can i do besides choppin the origional ones?? let me know.. cheers guys
  14. hey guys with the price of petrol these days does anyone know what the fuel consumption of a 4age and 4agze?? litres to 100km driving normal that is!! cheers cam
  15. hey fellas. just bought i tacho got it all wired up sweet. only problem i need to wire a yellow wire up to some where to get the tacho lights to come on when i turn my car lights on.. any info would be sweet cheers cam
