hey fellas. just bought i tacho got it all wired up sweet. only problem i need to wire a yellow wire up to some where to get the tacho lights to come on when i turn my car lights on..
any info would be sweet
cheers
cam
cheers
cam
grab a multimeter
find a wire in the dash cluster which has 12v switched by the headlights switch
ie.
headlights on = +12v
headlights off = 0v
tap in there for your yellow wire
Hey cam, care to share som info into how you wired it?
ive got an old tacho sitting at home and i lost the wiring instructions for so I'm not sure how to do it
Any more info on the specific car you are wiring it to? What make/model?
Usually you wire it up to your park light circuit so when you turn your park lights on it will illuminate the tacho..
Just wire it to the park ligt fuse..
In most cases,
Green : neg of dizzy
Red : power
Black : earth
Yellow/white : park light fuse
Deffinately parks, not headights. If you wire it to the headlights, it'll probably turn off when you use high beam. on the parkers it won't. :fuzz:
