Trufauru Posted October 25, 2007 Report Posted October 25, 2007 in a web where a guy put an engine in the trunk of his acura, he do this with the brakes and then says No longer front wheel drive, thus no front drive axles, I used a 1" grade 8 fine thread bolt torqued to 192 ft.-lbs. to hold the preload on the front wheel bearings. There is a conversion formula to calculate bolt torque for equivalent tension load between two different bolt sizes and thread pitch. I also made a small bushing to hold the 1" bolt centered in the splined hole in the hub. the ones not painted are form a CE110 and the red ones from a KE70, can something be done??? and for the record I'm form uruguay so, no AE86, no RX7, no Silvias/200sx to take brakes from thanks in advance Sebastian OUt Quote
VHR32 Posted October 28, 2007 Report Posted October 28, 2007 I see what you want to do. the answer is maybe it can be done, you wont be able to swap the lower control arm though. Quote
tas_ae71 Posted October 29, 2007 Report Posted October 29, 2007 do you want to swap just the brakes or the whole setup..? suspension, strut etc? Quote
