Hi all,
How the hell do you get the back seats out of a KE70?
It doesn't say in the Gregory's manual and I don't have an original owners manual
Some clown put 6x9's in the parcel shelf without scewing them in or cutting the holes properly :) , what a pain in the ass!
Plus i like to be able to take the lower back seat out to fit more of my guitars/amps etc in.
Any info appreciated
Cheers,
Tom
Cheers mate i did try that but i'll try again - i'm guessing u gotta pull pretty hard...
There is a bolt or two retaining the slides, you may need to push the backrest and seat apart and use a socket extension on the bolt, then it should lift out ok. The slides are either side a few inches in from the doors. Good luck.
ah yes, you should undo the bottom of the rear seat and take that out first.
