How hard is this to make? Is there any rocket science to it? It's just a big metal ring with 2 tabs welded to it to bolt to the floorpan right? How big should the loop be? I believe Jamie has one? Where did you get it from?
sometimes guys just make a U shaped piece of metal and bolt that to the floor, an upper just stops the floorpan getting chopped up if the front uni lets go. i got mine from sydney speed supplies 02 9607 2299 it was $40
Yes, a friend of mine running a 20V 4AGE KE35 in 3J pretty much ruined his gearbox and diff, and damaged his rear suspension as well when he pole vaulted it down the track...
