Gear Ratios, Etc
Have been speaking to Andrew Vibert from Central Victorian Auto Parts, he used to rally a JDM TE37 (which has unfortunately now been sold...), he's been rallying that car for a good 8 years now and was the Vic 2WD champion last year so knows a thing or two about rallying Corollas...
Anyways, we got to talking about gear ratios (since I'm looking for 4.3 gears), and the topic came up about the gearset from Palmside NZ, and also the gearsets that Albins has, and I mentioned that Rob was thinking of getting the Palmside gears... Anyways, here is some of the conversation (in lots of pieces):
Ivan albins has close ratio gearsets
for T50 boxes. He is in Ballarat. If he is going to use 4.77 gears then he
will need to think really carefully about gear ratios. To have a nice box
you really require 5.1 or lower.
Just out of interest I looked up the Palmside NZ T50 gearset, and
these are the ratios:
1st 2.63  2nd 1.89  3rd 1.34  4th 1.1 & 5th .86
Specs of gears available
Note: Prices are ex GST.
Gear Ratios 1st 2nd 3rd 4th 5th Reverse
Synchro Gear Set $570AUD $570AUD $450AUD
T 50 Albins Gear #1 2.39 1.61 1.21 1.00 0.886 3.48
T 50 Albins Gear #2 2.44 1.66 1.24 1.00 0.886 3.48
T 50 Albins Gear #3* 2.51 >1.75 1.28 1.00 0.886 3.48
>1.84*optional for Gear set 3
Comparison Specs
T-50 Factory/Standard 3.587 2.022 1.384 1.00 0.861 3.48
T-50 TRD#1 2.63 1.891 1.38 1.00 0.861 3.48
T-50 TRD#2 2.341 1.607 1.195 1.00 0.886 3.48
T-50 TRD#3 2.960 1.607 1.195 1.00 0.886 3.48
T-50 Quaife 2.347 1.733 1.379 1.144 1.0 3.48
K-50 3.79 2.22 1.44 1 0.87 4.32
AE 101 Transaxle 3.166 1.904 1.392 1.031 0.815 3.250
Caterham 6 Speed 2.69 2.01 1.59 1.32 1.13 1.0 (6th)
As taken from Phil Bradshaws site.
Ivan actually made me a special set of gears when I ran a 4.875 diff.
1st-2.6, 2nd-1.84,3rd-1.384 (std) 4th &5th STD. It had a bit of a gap from
3rd to 4th.
After a couple of events I changed to a 5.125diff and changed the box to
1st- 2.44,2nd-1.66,3rd-1.24with std 4th &5th. It was great with no gaps.
Have a play with this calculator and you will see what I mean. A standard
TRD box  has a 2.34 1st and it is to tall even with a 5.1 diff
I forgot. If he wants to ring Ivan make sure he mentions me. Ivan did the
first one of these boxes for me many years ago.
He also gave me a gear calculator thingy (Excel spreadsheet) but I have nowhere to put it.
Anyway, thought it would be of interest (in particular to Rob)
the palmside gear set is actually a TRD one, i can get those cheaper as we are official TRD dealers, whereas palmside arnt.
id be keen for that exel spreadsheet if you can email it :dance:
This probably isn't going to line up, but let's see how it goes anyway :dance:
Palmside NZ
Gear	Ratio	Final drive	1000	2000	3000	4000	5000	6000	7000	8000
1	2.63	4.77	8.7	17.4	26.0	34.7	43.4	52.1	60.7	69.4
2	1.89	4.77	12.1	24.2	36.2	48.3	60.4	72.5	84.5	96.6
3	1.34	4.77	17.0	34.1	51.1	68.1	85.2	102.2	119.2	136.3
4	1	4.77	22.8	45.6	68.5	91.3	114.1	136.9	159.8	182.6
5	0.861	4.77	26.5	53.0	79.5	106.0	132.5	159.1	185.6	212.1
Andrew's final gearset
1	2.44	5.125	8.7	17.4	26.1	34.8	43.5	52.2	60.9	69.7
2	1.66	5.125	12.8	25.6	38.4	51.2	64.0	76.8	89.6	102.4
3	1.24	5.125	17.1	34.3	51.4	68.5	85.7	102.8	119.9	137.1
4	1	5.125	21.2	42.5	63.7	85.0	106.2	127.5	148.7	169.9
5	0.861	5.125	24.7	49.3	74.0	98.7	123.4	148.0	172.7	197.4
well you gotta have goals....
33030-ae811 $2580nz
33030-ae851 $1770nz
just add freight :dance:
Umm, according to the Palmside page, they sell theirs for NZD2000 fitted? I'd imagine it would be a fair bit cheaper for just parts?
*edit* oh yeah, emailed you that gear calculator too
Edited by demuire
yup thats the cheap one, and its plus gst (12.5%) which makes it $2250.
cheers :dance:
