just get more power ;)
you can get proper brake line clamps (For when u take a caliper off, so u don't drain the system etc) these are good for doing the odd skid with |blink|
yeh i know but I'm only fitting it for a bit of fun then might put it on another car
guess what i was really asking is...
if i put it on the line to the fronts then it will lock the pressure on the front like its designed to.
but
should i put it on the line to the rears and reverse it so that it blocks the pressure to the backs so all the pressure goes to the front when i put the brake on
just wanted to now what works best guess its just a general thing
Wow, tripple post!
The original use of a line lock is for drag racing, locking your brakes on so you don't creep and 'red light'.
In this cirumstance you would install it in the fronts.
For burnouts it goes in the rear, usually just before the hose that drops down to the diff. ;)
I guess you could put it in the fronts for burnouts, but that would be a pretty boring burnout |blink|
