I have a corolla SR5 AE86 but the engine is a 1.3, looking to upgrade to a 3S-GE, can it be done and if so, are there guidelines or notes to it and pehaps a how-to online?
It has been done, best bet would probably be trying to get a JDM Altezza RS200 front cut for the engine and gearbox, ecu and wiring. Google is your friend.
Can be done using any model 3s but the altezza beams RWD one is alot easier.
The 3SGE has all the bolt holes for engine mounts (i know my mr2 gen2 3s does) so it would just be straight forward with engine mounts.
A 4y or 2s bell housing mates it up to a W5* gearbox then a cross memner will need to be made for that.
Then the intake manifold needs to be modded as the throttle is facing the wrong way and at a guess the maniolfd is too tall and will foul on a few things.
I'm doing this into a KE70 at the moment. I'm using a gen2 3s from an mr2. I already have a modded intake manifold using silver top 20v throttles. I have a 4y bellhousing. Ill be doing a write up as i go along as how I did it all.
