February 24, 200818 yr comment_229745 I want to put rack & pinion steering in my ke30 and just wanna know what other people have used and how they went about it. I have an ae71 steering rack i can use, just need to know if i have to shorten anything Any tips will be appreciated. Cheers, Eddie. Report
February 25, 200818 yr comment_229775 put a rack and pinion in my te71 u need a ke70 or ae71 rack and steering column then its bolt in u may have to grind a bit off the firewall for clearence thoough Report
February 25, 200818 yr comment_229778 put a rack and pinion in my te71 u need a ke70 or ae71 rack and steering column then its bolt in u may have to grind a bit off the firewall for clearence thoough That probably wont work for a KE30 though, as i'm pretty certain the track width is different. And most likely it wont "bolt in" as the chassis is kinda different.... Edited February 25, 200818 yr by Xany Report
February 25, 200818 yr comment_229802 true i don't know much about them so i can't answer perfectly i also remebered ur crossmember will need rack mounts Report
